Hi,
i finally jumped on board the Fujifilm train and bought a second hand X-Pro 2, it’s missing the manual, software, usb cable and the camera strap lugs. Apart from eBay where’s the best place to get these items?  I’d love to get direct from Fuji but I’ve not t had any replies to my emails.
Thanks in advance.
