Looking for the same thing, but using Scotty Wang's X-T2 versions until Capture One's official ICC sims will be released…They work pretty good so far, but my bet is that the colour wizards at Phase One will create something great…
I am using those profiles and agree that they work well. It's just that I don't want to wait for Phase One to deliver. LOL
