I upgraded the firmware on my X-E3, something I usually wait to do but am leaving on a trip so took the chance/opportunity.  Turned on the unit and noticed that my EVF and LCD screen both pulse bright to dark and back while the shutter button is pressed halfway.  Is this some new feature that I am just clueless about or a bug in the firmware?
