Temps in the mid-30's and mostly overcast skies, but a marvelous solo hike in the Nature Preserve. The trees, rocks, and shrubs had a magical quality, and I was filled with joy.
Connecting with Nature, Earth, and Spirit is vital during these challenging times, and always offers a much wider and deeper perspective.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
