Hi folks,
I want to share a new article that I just published on my website. It is named: India on 16mm and 35mm with Fujifilm.
Come check it out in the following link: Everyday life scenes: India on 16mm and 35mm with Fujifilm
All the pictures were taken in august 2016 with my old X-T1. My passion is documentary photography, and I would like to recommend you to read this article if you are interested in the 16mm and the 35mm for your next adventure far from your comfy home.
You can follow me here:
Instagram: jose_carpin_photographer
The following picture is just an advance. You can see the rest in the article:
Edited by Jose Carpin
