THE EXHIBITION HAS NOW CLOSED AFTER 18 MONTHS AND OVER ONE MILLION VISITORS
LONG-TERM EXHIBITION OF FUJI STREET PHOTOGRAPHY IN CENTRAL MILAN, ITALY - 50 IMAGES - 200 METRES FROM DUOMO - FREE ADMISSION - ALL IMAGES WITH FUJI X CAMERAS
