Another exciting adventure on the river today. Definitely autumn, with the morning chill necessitating warmer clothing. But the sun warmed things up after a bit, and although there were no headwinds, the current was still quite strong in various places.
The trip back was a different story, as wind gusts up to 25 knots made paddling very challenging. Waves broke over the bow, and the kayaks were blown sideways at times. The adrenalin rush was helpful, and we made it back safely.
Sightings included Canada geese, Ospreys, and a large flock of Blue-winged teal in addition to herons, ravens and turkey vultures. And as always, the stillness, solitude, and deep connections with nature and spirit were inspiring and uplifting.
These are photos of the rock cliffs at Cochiti Canyon, where we stopped for lunch.
1.
2.
3.
4.
5.
6.
7.
