Walking around in Utrecht city centre with the 35/1.4 on the X-Pro1.
Unfortunately not really sharp, but I love the colours - don't think this will be a long term keeper though.
In front of the bakery near the Maartensbrug bridge.
Where Love is Illegal - photo exhibition at the Domplein square, to raise attention for the suppression of LGBT people.
Laced-Up Boutique - obviously a lingerie boutique, close to the Janskerkhof square.
Domplein square, one of the busiest spots in the city (together with the canals).
