Problem with Mitakon 35mm 0,95
By Sandro_gsp · Posted
ooohhh I just checked ... you are right ! anyway for old pictures, the Exiftool or photolab9+FilmSImulatioPack are still necessary. -
OH! I hadn't even noticed that the dial had moved from S! Thank you! 🙏🏼 This is something I hate about this camera - this dial moves on its own, you can't fix it so it doesn't move onto a different setting! 🤦🏻
Reala ACE has been available on the X-H2S since firmware version 7.0
I noticed some of what you are describing, but in my images, the difference seems more related to the body than the chosen simulation. Images from my X-T10 are slightly more yellow tinted than the ones from my X-T30 or X-T30 II (or the newer bodies have slightly more neutral auto white balances than the older one does if you want to think of it that way). I shoot raw and use Provis as the base simulation in all of the bodies because it is so neutral to start with, I can tell during a quick image playback if I have over-cooked an exposure.
