Hi -  I'm hoping someone here can help me.  I've gone through the user manual and a few Google searches and haven't found an answer.
I have a job requirement to show the date and time stamp ON the digital image.  They don't want a print and they don't want to see the date/time in the EXIF data.  They want to view the file on the monitor and see the date/time stamp on the image.  Is there a setting on the XT-1 that will give me that?
Thanks in advance!
No, I don't know of any serious camera that offers this option.
I haven't done it myself, but if you have a Windows computer, you supposedly can use the free FastStone Image Viewer software to timestamp your photos. Instructions here: http://soft.mydiv.org/win/qans.t103873.how-to-add-timestamp-to-multiple-photos-in-faststone-image-viewer-.0-Faststone-Image-Viewer.html
Caution: I've seen some indications that process overwrites the files it's stamping. You probably want to work on copies to be sure your originals are safe.
Edited by Doug Pardee
    • Also, there's a setting "Shoot without a lens" that needs to be turned on for lenses with no contacts and adapted manual lenses, otherwise the camera won't respond to the shutter button when you have a manual/old/no contact lens attached.
    • So, the lens isn't focusing. What is the original lens you were using? Is the camera switched to an auto-focus mode? S or C
    • When I look through the view finder it’s blurred along with the image showing on the screen. So when I take the picture it comes out blurry as well. The information is still showing clearly on both the screen and viewfinder.  I bought a cheap lens from pocket dispo and when I put that one on the camera I can see the images clearly through the viewfinder with no problem but I’m unable to take a picture.  I’m not sure but I thought the lens would click into place when attached to the camera but I’m not hearing that noise anymore. Tried to upload a picture of the camera but it’s saying the file is too large.
    • Bald Eagle being buzzed by a Crow in Oregon. Couldn't get the Crow in the frame it was moving too quickly. X-H2s, Fuji 150-600.
    • Hi there,  I just got a DJI video transmission system and want set it up with my GFX 100 II.  The problem is, that it doesn't work when I connect the HDMI cable to the transmitter.  The camera display goes on and off about every second and there is no video transmission.  Has anyone had the same issue?  I have checked the following: - the HDMI video resolution is set to FHD 16:9 30fps - HDMI output settings: output info display is set to OFF - HDMI output settings: HDMI rec control is set to OFF - HDMI output settings: RAW output settings set to OFF - The latest firmware is installed on both the camera and the DJI transmitter  - Both the camera and transmitter have fully charged battery  - Video transmission from another camera works [using a different cable, though A <-> B ] I have tried 2 different HDMI cables and tomorrow I'll test it with another "ultra-fast" one.  Omitting the transmitter and connecting the camera directly to the DJI High-Bright Remote Monitor works perfectly with both cables I've tried.  Have you heard about any HDMI problems with Fujifilm cameras?  Do you have any suggestions?
