A sunny and warm day in the Nature Preserve.  Despite recent rains, the trail was surprisingly dry, due to the intense sunlight.  My partner was at a retreat in the Bay Area, so I was on my own.  But I still did a bit of off-trail scrambling to get some of the photographs.
The trees, rocks, and vistas were inspiring and uplifting, as were the deep connections with nature and spirit.  Food for the soul!
1.
2.
3.
4.
5.
6.
7.
8.
9.
