The 55-200 is my least thought of lens. Sitting in the bottom of my bag of lenses I really only bring it out when I go to the mortocross track. There I basically beat the crap out of it, letting it get dusty, wet, using my sleeve to wipe of the dust... and everytime I walk away amazed at the quality of the images! Mind you, in insufficient light, it's another story but when light isn't a problem this lens is fantastic, especially at the price!
Here are some pics of a Red Bull Rocks and Logs event this weekend. Ideally, you want to have the rider coming at you but unfortunately due to the limited access for spectators we were unable to see them coming for the good parts!
Here are a couple more
Yeah, this lens is a kind of sleeper lens. You always forget to bringing it along, but its pictures are quite stunning at some moments.
Also for portaits it's a very nice one actually. Not always as bitingly sharp as the primes, but very versatile and a pleasant rendering and sharpness rolloff.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
