To follow on from previous posts on the Milky Way here is one taken last week of the Milky Way over Cathedral Rock, Anna Bay, a lot of light pollution from house on the next peninsular of Fishermans Bay. Exif, XT1 (such a great camera for night photography) Samyang 12mm f2, 52s exposure, remote
