I guess but I'm not definitely sure if this happened after the latest firmware update, or irrespective of that. Anyway, as the manual says the chosen ISO setting should stay chosen, not resetting, after the camera is shut down. AND this was the case previously. But now it isn't. So, every time I shut the camera the ISO setting turns back to the default value I've chosen, for example 500 ASA even though it was something else when I took photos. I don't find a way to fix this. Hints?
I reply to myself, as - after searching and experimenting this and that during several days - I found today the reason to my problem... Should I tell that, as I haven't got any comments from you, the community? Ok, jokes apart. THE point is that the option Auto update custom settings under Image quality settings needs to be ENABLED! Well, as the manual is so obscure, not specific, with too short explanations and too general, I needed some 1-2 weeks (of course not day and night ;) to find the solution. Anyway, now my X-T50's ISO setting holds, to that I set it.
By the way, the camera with the quality of the pictures, is great!!!! I love X-T50 after my reliable Nikon.
Well, one more thing, I would like this working: I transfer pictures to my Mac by using the app Photo transfer by wire because it is hazardous to take the memory card from the camera and put it to my MacBookPro because after Mac's reading the X-T50 doesn't recognise it any more!! Nothing but formatting the card *in my Nikon* helps, to get X-T50 to work with the card. So are there for this second issue any solutions??
It seems good you were able to find an answer to your question shortly after posing it.
As to your remaining question, can you give some more details? Because what you are describing is very unusual. Which card reader were you using to move the images to your computer? Were you double clicking the card’s disk image to open it and then using the finder to select all of the images you wanted to move, then dragging them over to a folder on your Mac? Did you use the eject command before removing the card from the card reader?
There are a couple of things to also try. Take a few new images using a freshly formatted card, put the card in the reader. Open the app Image Capture and use it to move the photos. Use the eject command before removing the card and see it the card is still messed up.
If so, try again, but this time before putting the card in the reader, slide the write protect switch on the card to the protect spot. [The write protect switch is a small little tab on the side of the card.] Move the images, then use the eject command, remove the card, slide the write protect switch back to the unlock position and put it back in the camera.
Let us know how things go — uh yeah sometimes it can take a while to get an answer.
https://support.apple.com/guide/image-capture/welcome/mac
Edited by jerryy
Yes the second question is unusual. I always put cards from my X-T5 and X100V into my Mac to transfer and have no issues when putting back into the camera.  I don’t ever delete or format the cards using my Mac. Once I’ve copied the photos to my Mac I use the camera to format the card.
I’ve always heard that should format in camera to lower chance of issues and ensure file system is compatible with the specific camera.
Edited by abmet
    • Back on page three of this thread is an image and mention of those mythological and astronomical twins, Castor and Pollux. They are back for your viewing pleasure in the night sky with Jupiter joining them, an added bonus this year. At least for those stargazing in the Northern Hemisphere anyway. For right now, you will need to wait until late at night, Very Late. or Very Early in the morning if your clock works that way. A little after midnight. Look a little to the left of Orion and there these three will be forming an arc.
      Procyon is along for the arc ride... As long as the clouds are not too much, the arc is visible even in cloudy, light polluted skies like the one shown here. This is the equivalent of a just almost but not quite ten minutes stars exposure with a five seconds clouds exposure.
