Hi everyone, I own a Fujifilm X-H2, but for the past month, I've been having a problem. When I connect my monitor to my camera, the camera's screen keeps turning off and on repeatedly, regardless of the HDMI cable or monitor I use. Resetting the camera hasn't made a difference. Am I the only one experiencing this issue?
