Hi
Downloaded the newest firmware and have shot a few test photos with the Reala Ace profile. For now it only seems to work with being burned into the jpeg files. When I looked through the camera matching profiles in lightroom it contained every other color profile than Reala. I heard from someone that the X100VI has that embedded in the Raf files, does anyone know if this is true? It would make sense for the H2S to have the profiles embedded as well. If one cannot re add the profile in post it makes the update kind of meh. At least for the ones who like to shoot raw.
Hoping this is an oversight and will get included. Would appreciate of anyone has the specs on this, (or a fix.)
When I look in Lightroom, under colour profile, camera matching, I see Reala Ace as a choice. But I've been lead to believe that those are Adobe's versions, not the actual Fuji simulations.
Is your Adobe Camera Raw and Lightroom up to date?
Lightroom Classic V 13.4
Camera Raw V 16.4
Edited by pw-pix
Hi
Both Lightroom and cameraraw are upgraded to those versions yes. Are you using an H2S and getting reala ace? I have 19 camera matching profiles as of now. Maybe it could help to format the memory card? If RAF files from before the firmware that do not contain that profile live side by side with the new files. But the Exif info should exist individually for the files I think. So by common logic that should not play any part.
I have an X-T5, and this was before the firmware update V4 that added the Reala Ace to the camera. I'm pretty sure my Lightroom was showing 20 camera matching profiles.
6 hours ago, Porridge said:
Hi
Give it time. The firmware is new and Adobe haven't got around to including Reala Ace in the list of film simulations allowed with the X-H2S. They only allow film simulations supported by the camera and create their own versions of those film simulations.
You can be assured that the X-H2S has the code embedded in the RAF file (and also a preview jpg with the film simulation applied).
You can prove to yourself that the RAF file includes the Reala Ace simulation by opening the file in Fujifilm X Raw Studio.
I think that must be the case. Did some tests.
Can confirm that reala shows up as a profile in fuji raw for h2s.
Nuked the memory card, it did not make any difference. Importing as Raf vs Dng did nothing.
Guess it`s a lightroom thing. Looking forward to them fixing it. Weird if it works on xt-5 though.
Thanks for all the replies and help y`all
