X-T2: Winter Sleigh Derby
GilBarib
Hi
Here a few from a Winter Sleigh Derby.
For those of you not familiar with the sport these are time trials races on a 380 meters course with 8 gates and 6 fence-like obstacles.
Each team has to go thru the gates and around the obstacles in the shortest time, but there is a 5 seconds penalty if they knock down the small balls sitting on top of the cones of a gate.
Same thing with the small wooden block sitting on one of the post of the fence obstacles, those will make them loose a extra 10 sec each.
And to make it a bit more challenging, the course is not linear but rather randomly set in a 100 x 100 meter field and you have to do it in the right order.
The gates are numbered from 1 to 8 and the obstacle from A to F, first they'll do all the gates in order and then go around each of the obstacles once again in order, get it wrong and it's a disqualification.
For the horse handlers (les meneurs) it's more about control and finesse than brute power and speed,
It's a great type of race to photography since they will pass in front of you a few time, so you get a chance to shoot from a variety of different angles all while standing on the same spot.
Shot in AFC with a gripped X-T2 on boost at 11 fps ( great to catch the horses with four hooves in the air).  The XF50-140's range was perfect for shooting from different angles.
Shot in Raw, PP in LR 6.8, Irident's X-Transformer and Nik's PreSharp + ColorFX.
The Flickr Album (44 pics as of now): https://flic.kr/s/aHskSW6jvd
32460353946_a221e0246c_b.jpgDerby de Shannon #49 by Gilles Baribeau, on Flickr
31675638273_ec15e6f18c_b.jpgDerby de Shannon #42 by Gilles Baribeau, on Flickr
32365217621_5d84a6d23d_b.jpgDerby de Shannon #23 by Gilles Baribeau, on Flickr
31636849783_5d92c13a1b_b.jpgDerby de Shannon #9 by Gilles Baribeau, on Flickr
32297453562_9fbf403509_b.jpgDerby de Shannon #11 by Gilles Baribeau, on Flickr
31605078214_8584aedeb3_b.jpgDerby de Shannon #4 by Gilles Baribeau, on Flickr
31675567443_1612a8cfe3_b.jpgDerby de Shannon #41 by Gilles Baribeau, on Flickr
Hi again !
Here's a few more from another Derby (I think I'm starting to love shooting horses)....
31768742634_00c3df6288_b.jpgDerby La Durantaye #18 by Gilles Baribeau, on Flickr
31799939943_a7054329a8_b.jpgDerby La Durantaye #17 by Gilles Baribeau, on Flickr
32435723782_ee1e931a8d_b.jpgDerby La Durantaye #6 by Gilles Baribeau, on Flickr
32548066516_3db1a59793_b.jpgDerby La Durantaye #5 by Gilles Baribeau, on Flickr
32209312090_6321d2aea9_b.jpgDerby La Durantaye #2 by Gilles Baribeau, on Flickr
    • So I ended up getting and X-H2 over the X-T5 because of a good deal that came up.  Needing to buy a card, I needed to figure out,  what is the real impact of a card's speed for photos?   In particular, I'm going to test how shooting at 15 FPS will differ between: Angelbird - AV PRO CFexpress B SE - 512 GB and Angelbird AV PRO CFexpress SX - 160 GB. How many shots can I get off before buffer fills, and how long does it take for the buffer to clear?    MOP: X-H2 Factory rest, card formated, no lens (body cap on), performance boost on, manual exposure, mechanical SS @ 1/8000, IS off, Shoting RAW Compressed Lossless with only one card in. Held shutter release till buffer filled, and used stop watch to see how long for buffer to clear. Subtracted two frames from total taken as that's how long it takes me to release the trigger once the buffer is full. Repeat 2x for sanity check.   ***TEST RESULTS***   ~~~64GB Lexar Pro SD 150MB/s~~~ 75 shots to fill buffer, 36 Seconds to clear it   ~~~Angelbird AV Pro SX 160GB~~~ 251 shots to fill buffer, 5 Seconds to clear it   .~~~Angelbird AV Pro SE 512GB~~~ 232 shots to fill buffer, 4 Seconds to clear it     ***Conculsion***   If burst shooting an X-H2 at 15 FPS is your thing, buy the Anglebird 512GB SE for the same price as the 160GB SX.   Below is a shot on X-T2 w/ the Fuji 70-300. I manged to fluke it off with a dead battery by turning the camera off and on again, and squeezing three more shots out (this was the last shot).   Ta for now!
    • Xt5 firmware updated and now cannot see pics taken on lcd when pressing playback. Any ideas please? Elie
    • Have you tried a factory reset? Maybe you changed unintentionally a setting?
    • Hello. I have a x-s10 that I use multiple lenses with. Yesterday I noticed that with the Fujinon 16mm lens I'm having issues auto-focusing. It works on video but not for still images. When I half press the button it focuses a bit then when I release the button it snaps back to the previous focus point. Even though it manages to focus the image is still blurry. Any ideas please. I already did a a major google search and nobody has mentioned this issue. Thanks, Etienne
