Hi, I wanted to say that I am a new member and to introduce myself. I am a fuji convert , having used Canon 5d's for years I decided to get a smaller camera so that I didnt have to lug a massive backpack around , long story short ,, my canon gear stays in the cupboard now , I love the results I get fro the Fuji. I am a Retoucher for a high end advertising photographer so I spend my days working on 100mpx Phase One files, one thing I have noticed is that the Fuji files are very comparable when it comes to dynamic range and sharpness, obviously not resolution but they hold their own! I have had a few fuji cameras and up until I bought the Fuji Xpro 2 I always had niggles with certain aspects , now however I feel that Fuji is as good if not better than the DSLR's I am used to. I currently use the 35m 1.4 and the 18mm, and I love them both, the colours you get from this little beast are second to none. If you feel inclined take a look at my work ,,
Retouching - www.alextelfer.com      -     (he's my boss)
Instagram -https://www.instagram.com/itchphoto/       -   (mostly shot on Fuji)
Si
