Antique 19th century comb carved from water buffalo horn from Sumba island, Indonesia
Our never-ending product shoot - 71 down, 280 to go. This time an antique 19th century comb carved from water buffalo horn from the island of Sumba in Indonesia. Shot first on a piece of wet ironwood for a bit of drama, and then in our usual teak bowl for a bit of contrast. Enjoy... :)
