Just bought xe1 any tips on setup pls
It seems there isn't a definitive solution to resolve "NEW FIRMWARE NOT TO BE FOUND. TURN OFF THE CAMERA." I have 3 x prime lenses for my XE-2, and recently fell back into using it daily after a very long time. As it had been so long, I first upgraded the body to 4.11, then tried to update each of my lenses. Not one download (.DAT) file has worked on either. Due diligence was executed whilst trying to update the firmware on each lens to no avail. I'm savvy with upgrades and tried: formatting repeatedly, different computers & cards, downloading files direct to card, using different batteries, lens on, lens off, checking file names, and even balancing on my thumb whilst performing the former, but, still no joy. So, has anybody successfully updated a lens from 1.00 to 1.01 or beyond on an XE-2 running firmware version 4.11? Maybe, the answer is, the XE-2 running 4.11 firmware does not support any lens updates from 2019, but a response from google ai discounts that. I'd be grateful for for any help on the above. 🙏🏼
I installed X-Webcam on MacOS Sequilla 15. I've set the camera: 1. Wrench - Connection Mode - X Webcam 2. AF/MF - Face/Eye Detection Setting - Face Detection ON - EYE Auto , then i link the camera to the laptop use both a USB Type C cable and an HDMI micro cable. The FujiFilm Cam isn't detected on Zoom app, Tella, or Loom camera options. Hw to fix this? -
X100vi user here, and I faced the same problem too. I did not have RAW switched on, but I chose FINE/HEIF and got the "no image in the memory card" message. After reading the posts here, I change to FINE/JPEG and problem solved. Thanks for the posts.
By Hillsidebeer · Posted
Yes, I managed to replicate the issue - took a photo, numbered DSCF1232. Copied to the SSD drive, where is appears as DSCF1233. Take a second photo on the camera - this is DSCF1234. -
Interesting - sounds like you've found the reason for the discrepancy - I guess the SSD drive option is new to FujiFilm and they don't have it quite right yet
