We made our annual pilgrimage to Islington, London last weekend to attend the Angel Festival, a great day with fun and friendly people with a mix of stalls along the canal towpath.
I travelled light as I was helping my wife on her stall so took just the X70 and managed to grab some street shots as well as some at the festival.
A fun day was had by one and all.
