I'm using x-s10 with 18-55mm 2.8f lens. A week ago I've got message "turn off the camera and turn on again" without any known for me reason. I took out battery, lens, sd card and after few hours I was able to use it. Next day the same story, so I plugged sd card via card reader to my smartphone, cleared it out. I'm using the newest firmware for the camera and lens. I'm not able to take pictures for 3 days already...
When I point the camera to the ceiling I see that the screen is a little bit wobbling so I suspect that sth is wrong with IBIS.
Have any of you had such an issue with your camera? What have you done in this case?
Edited by Sebastian S
