A couple of pictures from the flood cleanup in Baton Rouge last weekend.
X-Pro2, 18-135mm @56mm, f5, 1/150, ISO 500
X-Pro2, 18-135mm @41mm, f4.5, 1/160, ISO 400, Cactus flash off-camera
