Tilt Shift
So, your 15-45 is broken/faulty. Take it back where you bought it for replacement.
I have the lens that came with the camera. It’s the 15-45mm. I’ve tried to moving both pieces in the lens but it doesn’t seem to do anything. I’m pretty sure the piece closest was zooming in & out but it doesn’t do that anymore.
By MARRIEDGUY9 · Posted
playing with trails at Assateague Island.......bout an hour and a half, Milky Way rising in the bottom throughoutWelcome, dear visitor! As registered member you'd see an image here…
Also, there's a setting "Shoot without a lens" that needs to be turned on for lenses with no contacts and adapted manual lenses, otherwise the camera won't respond to the shutter button when you have a manual/old/no contact lens attached.
