It is not on the list of lenses that can resolve the 40mpx sensor provided
at Fuji Rumors but there is controversy about it being up to date as it is
a newer lens brought out about the same time.
Have asked and searched for the answer myself to no avail.
Bought the lens anyway a few weeks ago and am tickled silly with it.
Its a fabulous and sharp lens IMO and so useful with its macro and ability
to focus almost any distance. Hopefully you will find yours to be the same.
