I just downloaded the new 2.00 firmware on both my X-T30-II bodies.
Just to let you know it loaded just fine and the cameras seem to work as before
The only thing you need to do is set the timezone, date and time as it prompts you.
I used one of the bodies to update my 100-400 XF and that worked fine as well.
I installed the new X-APP on both my iPhone X and iPad Air and that installed just fine. I'll try it out this evening but it looks nice.
So far, so good. Nothing bricked or failed to install.
Hello,
Can anybody help me to find the download page for 2.00 firmware?
The link in the previous message doesn't work in Italy and when I go to the download page I can only download the file named FWUP0029.DAT that is the previous firmware 1.21
Thank you
Enrico
Edited by Bimbo Gigi
