Hello,
I'm Marleen and I'm a fuji-fan from Belgium.
Started with the Fuji X-T1, and recently bought the X-T10 as back-up.
If you have any questions, just ask.
Regards,
Marleen.
welcome to the forum
Love Belgium. have been there a few times. Mainly in Antwerpen... Frituur Nr.1 Rocks... and above all else, I love the tripel karmeliet ;)
Ah Patrick, I see you know what our county is best in (among several other things of course)...
French fries and beer... LOL
Fuji regards,
Marleen.
