I'm perplexed with my x100t.
I notice that the 'Face Detection Focusing' icon only shows up in the EVF but not the OVF. The OVF only displays the 'Focus Area' icon, weather I choose Face Detection or not. If so how am I to know if I've chosen Face Detection or Focusing Area while viewing thru the OVF? And more importantly is Face Detection focusing operational in the OVF mode?
The face detection icon only shows in EVF, but not the OVF or hybrid OVF viewfinder w/ EVF overlay in corner. I did more research elsewhere and found face detection only works while in the EVF mode.
