Shutter release not working with Meike 1.7/35 mm
By Sandro_gsp · Posted
I haven't had any problem with my XH2s and CFexpress card, but I struggled for almost 1 year with a 256GB SD card . To cut it short : I finally solved the problem formatting the SD card using windows DiskPart command. I think the key was removing everyting from the SD card using the "clean" command. Diskpart is rather technical, I hope you can understand how to use it. Search google for : "diskpart erase partitions" Hope this helps. -
By dannycooke · Posted
Hi, i’ve had a look around the internet and can’t seem to find anyone with this issue. Long story short is I used to be able to access my CF Express type B cards that are formatted by my XH2s on my pc and my mac. They would pop up as an external drive through an external Sabrient reader. Now they don’t?! Has something changed in the firmware? something broken. A few observations: It now happens with all of my Sabrient cards. I bought a new Lexar reader and it does it with that too. If i format the cards on my RED camera and then mount on the computer they work fine as expected. Once I put back in camera and format the card then place back to PC it doesn’t work. The only way i’ve been able to access the card is while it is plugged into the camera but this seems a lot slower to transfer data. Has anyone else noticed this? would appreciate any solutions. -
By bdigital79 · Posted
I know this is an old thread but I just ran into the same issue with my x100t. Wondering if you ever found a solve.
