Hi all, newbie here. Been using Fuji for around 6 years and just picked up an X-T5 a couple of months ago, coming from X-T2
Anyone thinking of the upgrade, particularly from a 2, it's good. Really good
Anyway, I've picked up at least one dust spot on the sensor, and depending on the file it does show. I can easily deal with that with healing, but I want to remove the dust
I've always undertaken my own sensor cleaning using Sensor Swabs, and their cleaner, with great success. I'm not a fan of using a blower, seems to create more dust problems than if fixes
So my question is, what do I do about IBIS when cleaning the sensor
What precautions should I take
Thank you in advance
Hi there, I always follow this procedure:
1. Turn the Camera on (and leave it on while cleaning).
2. Set IS mode to Off so the sensor remains locked in position.
3. Switch the shutter to ES - this prevents accidently closing the normal mechanical shutter while cleaning.
4. Turn "Shoot without Lens" to Off - this prevent the shutter from working with the lens removed
5. Turn Power Saving Mode to Off.
Once cleaning is done you can reverse all of these settings as required.
Thanks @strat68, appreciate the reply
I've not heard of leaving the cam on whilst doing a wet clean of the sensor
Is that to ensure no movement of the IBIS sensor?
And if yes, IF I wet clean the sensor with IBIS off but the camera also off, can we get some movement in the sensor still?
Cheers
Hi, sorry for the late reply. Yes, as far as I know it's better to have the camera switched on to lock the sensor in place. I've been using this method since I bought an X-T4 a few years ago with no problems. It seems to be the recommended practice. If you do a search on YouTube you'll find some more in-depth videos on the subject.
  • 2 years later...
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
      Winter is coming.
    • For some reason, the EV dial setting does not correlate to the EV setting displayed in the viewfinder.  My XT2 used to have parity between settings such that when the dial was at "0", the viewfinder also showed "0".  Has anybody else noticed this?  I've tried a reset of the s/w but no luck.
