There are usually a couple of ways or so to do this, have you tried:
Set the shutter speed to “A” and then use the lens’ aperture ring to choose the f-stop. Or
Use the command dial for f-stop by way of set the shutter speed to “A” as well as turn the aperture ring to “A” as well and then use the front command dial to change to f-stop.
