Hi, I’m going on a multi day hike with X-T3. No power. Remote.
I have plenty of spare batteries and a portable power unit, but it will not be enough for the days I am going.
Keen on hearing experiences with solar charging your camera batteries . Does anyone have a good recommendation for XT-3 solar battery charging?
