It looks like the mechanical shutter is giving out.
If it is still in warranty, then the place you bought it can help you get it repaired.
If it is out of warranty, your local camera store may be able to repair it or recommend a camera repair shop to fix it, get an estimate first to see if it is less expensive to get a different body.
p.s. DSLR cameras are not more reliable.
Edited by jerryy
