Under the FLASH SETTING/FLASH FUNCTION SETTING/SYNC TERMINAL on my X-T5, I can't switch it from OFF to M SYNC FRONT using the rear thumb wheel.
I have uploaded a photo my X-T5 menu showing the screen with OFF, and a photo of my X-T4 on which I can switch it to M SYNC FRONT.
I've run out of ideas... any solutions or ideas?
Thanks in advance,
Scot
