Hello everyone,
I have a GFX 50S II and since this morning I have a strange bug. When I want to look at the images from the card, they don't appear on the screen anymore. I can see them in the viewfinder but the screen remains black.
No problem to display the menu and the liveview but not the shot images.
Does anyone have an idea? Is it a technical problem or a function I activated without meaning to?
Thanks
Laurent
2 hours ago, Olaf W. said:
If I remember correctly you can change the display mode separately for playback and shooting. So my guess is you switched it to viewfinder in playback mode.
Great indication !  That was it. There is the "view mode" button on the right side of the viewfinder which I had never seen before. It allows you to switch from one mode to another to select the screen or the viewfinder or both.
Thank you very much.
