I have a new X-H2 and I must be doing something wrong.  I use Camera Remote to download photos when I'm traveling.  I'm getting very small size photo (1-5MB) JPEGS.  I get much larger jpegs when I download my X-Pro3 photos the same way.  If I take the card out of the X-H2 and download on my computer, I get the larger JPEGS.  I don't see any relevant setting on the APP.  The data save options on both cameras seem to be the same, although the X-Pro3 has a setting for "Save Orig Image" which doesn't appear on the x-H2.
I do not think you are doing anything wrong. The default for the app is to use the camera to make a smaller jpeg suitable for the screen of the device you are downloading the image to (such as a cell phone) and then copy that smaller file to the cell phone or whatever. Unless you change that “Save Org Image” setting in the body, then the larger file will be copied over to the tablet or cell phone running the Camera Remote app.
I do not know where that setting is for the X-H2 though.
    • Hello, I recently got a new x-s20 from Amazon. I checked the shutter count using XApp and it says 163. Should the shutter count be zero in a new camera? Some people say that it might be testing at the factory. Is this true?
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
