Hello, so yesterday after returning from the "photo shoot" I started to hear a loud grinding of the focus motor in both AF and MF. I also felt and still feel some vibrations in both modes. When I have loosened the UV filter it got quieter but it's still here. It is very similar to the noise in this movie (0.41s - 0.53s and 2.37s - 2.47s). The lens is still under warranty, but I don't know if I should worry about it. It's definitely weird, but AF and MF work fine (I think it works the same as before).
    • I am very tired of Fuji as a whole... They automatically deny responsibility on issues, quote crazy high repair prices and timeframes and when I accepted a (refurbished" replacement 100-400 instead of a repair because to would be cheaper and faster it developed the exact problem a couple years later, My XT4 is absolutely unreliable because of the turn on turn off issue that has persisted through numerous attempts to fix it and my 10 to 24 would not focus at infinity and struggled to focus at all, and I went through two of them because of focus issues. My sigma is much better.
