Maybe it will be more useful for Fujifilm to provide us (GFX users) with a  suitable tilt and shit wide angle lens  which is badly needed for architectural and landscape photography. I had spent over 15,000 Eur  in the system back in 2019 and that includes only the GFX 50s  as a camera body.. The rest of the money was spent on lenses, handgrip and tilting viewfinder which  has just stopped working..
It is only fair that Fuji take care of its clients especially after making a decision to switch camera systems from one brand to another. I have been taking my aging 50 s  even to cover yacht racing, although the focus system and frame progression is a huge disssappointment to say the least. as it takes a huge amount of time. I am a semi-professional and not a full time photographer, mostly engaged in art exhibitions and investment (especially at this day and age)  requires sacrifice... I expect that the system is given proper attention, now that it has lured users and clients to it!
I am at the point of buying a second body, a decision which I m still considering or changing back again to full frame... as since then both canon and nikon have come up with workable solutions...
Maybe it will be more useful for Fujifilm to provide us (GFX users) with a  suitable tilt and shit wide angle which is badly needed for architectural and landscape photography. I had spent over 15,000 Eur  in the system and that includes only the GFX 50s  as a camera body.. The rest are all lenses.
