Hi
When I was researching impressions of the new Fujinon XF 23mm f/1.4 R LM WR and how it pairs with different bodies I found very little info and/or images of the lens together with an X-E4 body. I therefore figured I should make a post about it so other people researching the same thing can find these picture and info. I have attached some pictures showcasing the lens on my X-E4 body. One very interesting/sad thing to note is that if the aperture ring is left at the 1.4 mark the auto lock knob/button will actually touch the flat surface on which the camera is placed which is not ideal. This is however not an issue when having the lens hood mounted, if a Peak Design style screw mount is attached or if moving the aperture ring to the 2.0 mark. All these pictures are taken with my phone so they are not really of stellar quality but are probably useful anyway :P
My overall impression of the lens thus far is really good, it produces very sharp images even fully open. It balances quite well with the X-E4; when actually shooting it feels really good but when carrying it around it is a bit front heavy. I found that there is a dramatic change in carrying comfort if the strap is mounted on the body in a diagonal fashion so to speak, i.e. with one anchor at either side of the body and one at the bottom screw mount. Using this configuration really offsets the balance point when carrying your camera diagonally, sling style.
Also, this is my first post at the forum so ... Hi all :)
Edited by silverjonsson
A couple of more pictures with the square Fujifilm lens hood (LH-XF23 II) I just recieved:
