Does anyone have insight on whether the XH2r will also have a CF express type B card slot like the XH2s.  I will be renting the XH2s and was wondering if I should go ahead and purchase the CF express sincei will be purchasing the XH2r when it is released. Also, I'm considering buying the battery grip, which I assume will be the same for both models.
    • I am very tired of Fuji as a whole... They automatically deny responsibility on issues, quote crazy high repair prices and timeframes and when I accepted a (refurbished" replacement 100-400 instead of a repair because to would be cheaper and faster it developed the exact problem a couple years later, My XT4 is absolutely unreliable because of the turn on turn off issue that has persisted through numerous attempts to fix it and my 10 to 24 would not focus at infinity and struggled to focus at all, and I went through two of them because of focus issues. My sigma is much better.
