I'm not sure if if this is the right bit of the forum for this question. I posted it here because I'm using an X-S10.
Currently I have 2 custom modes set up. C1 is set up for action shots, saving jpegs only. C2 is set up for low lights, with raw and jpeg. When I use one of the PASM modes I can use the camera matching profiles, along with a bunch of Adobe ones, in Lightroom Classic. When I use one of the customs I see a very limited set of profiles, not camera matching ones, or even Adobe ones. Also, it's not reporting the lens info either.
I'm a total noob in the Fujifilm world, pretty sure I'm missing something terribly obvious here. Any help would be greatly appreciated.
Thanks, Dany.
That makes sense. I checked the photos taken with custom modes and imported into Lightroom. They're all just jpg. Taking raw in C2 must've been a recent change I made and not imported into LR yet.
Thanks for that!
