Is the X-Pro 1 dead in the water re updates
By MARRIEDGUY9 · Posted
couple moreWelcome, dear visitor! As registered member you'd see an image here…
Heavily cropped ospreys..........good shots, just too far away. 150-600mm.Welcome, dear visitor! As registered member you'd see an image here…
Ocean City MD near Northside Park. 70-300.Welcome, dear visitor! As registered member you'd see an image here…
