Does anyone have this lens, and what are your experiences with it.
Looking as it is fast, and less than half the price of the XF56 F/1.2, granted no autofocus.
I have heard good things of other Samyang lenses (like the 12mm F/2) but not seen a lot about this one
Thanks in advance
I asked a colleague who had the lens on a Sony body and from what he told me:
The lens is good construction and the aperture ring clicks rather nicely. The focus ring is long and rather smooth but full open it is really a nightmare to shoot wide open, it is really super easy to miss the focus if you or your subject moves a bit too fast.
Very precise eye/hand coordination is needed.
Also from the pictures I could look at, the lend will be softer than the XF 56 1.2. But if you plain on using it mostly in a studio it wil' be a perfectly fine replacement for the fuji lens
thank you for your help
