For me has been almost two years into the X system, and in hindsight it's more obvious to me that it was one of the best decisions I've made. One of the places where that was quite obvious was last year in Cuba, when I was searching for my perspective on the island, and specially at that time I was there. A lightweight system that made the long walks in the streets under hot days, small that's discreete and it doesn't become intimidating and most of all very fun. Most of the photos from that one were shot with Fuji, despite also having a Nikon D800 (that nowadays serves mostly for landscape/nature).
Read more about it:
http://www.joaoalmeidaphotography.com/2016/01/mientras-tanto-en-cuba/
