New to Fuji camera user here testing out my brand new Fuji x-T4 & I dont see any change when IS Mode is set to IBIS/OIS or OFF & there is no icon at the top right indicating stabilization on my display.I've tried in movie mode & photo mode (IS mode Continuous) I did a firmware update to 1.40 on the Fuji body with no issues
I am using a Fringer EF-FX adapter & tried a manual Rokinon lens & a Canon EF lens.  I thought maybe I enabled or disabled a menu setting that might be preventing IBIS so I did a user setting reset on the camera as well.
Is there anything else that I might be missing to get IBIS functioning on my camera?
Thanks
