I just downloaded  the firmware version 1.25 via the fuji app on my new XT4 purchased in Munich on the 20.11.2021. Just after completion of the firmware download the camera went dead and will not turn on. It was working perfectly just before the download. The battery was full and in perfect working order. The slots had their memory card in and were properly formatted.  The objective was an Fujinon XF 35mm 1:2 R WR
Can any one tell me what to do to get the camera back on?
