Hi,  I am a newbie here and I have a question.  I would greatly appreciate your help. My ex T3 is frozen and I have tried everything. I have pulled the battery out and I have pulled the Sim cards out. I have put new battery in and you some cards in and the camera is still frozen and it says pairing to Smart phone. Can someone please help me??
How long did you leave the battery out?
Try leaving the battery out for at least four days to make sure the smaller internal “battery” completely discharges. You will have to re-enter all of your default menu settings again.
By Sim cards, do you mean the SD cards?
Were you trying to pair the camera to a phone?
