I'm not looking to shoot underwater, rather I want to be able to take my Fuji X100s whilst island hopping in the Philippines. I guess there's a small chance of falling out of the kayak, so need some sort of solution.
Any suggestions?
wel , you could use a waterproof “ bag” such as EWA marine
They are not the easiest thing to work with underwater but they are great at doing precisely what one would want to do with a camera while kayaking.
But they are NOT cheap or hassle-free!
I think that a real underwater case will be better and actually easier to use whilst offering way more capability should you want to take a dip in the beautiful waters of the Philippines.
The Meikon underwater case cost about the same as the Ewa Marine
@https://www.youtube.com/watch?v=MtPCw_25npk
@https://www.youtube.com/watch?v=3Tuq62EjAyE
