Hey guys so I just recently purchased my Fujifilm xt4, I took it out for the first time after setting it up. When I started taking pictures a realized it was starting to slowly freeze up after every few pictures taken. After freezing up two or three times I decided to see if removing the battery would help any. After doing that I lost about 30 images. I had to do it at least four other times during the shoot. Each time I had to retake all of the images I had just taken due to them disappearing. I just checked and I had Version 1.22, I just updated it to the Version 1.23. Im going to take some shots and see if that helps. if it doesn't does anyone have any ideas on what to try? I really love this camera other than this small issue.
