When using Camera Remote APP and I try to review images using import images selected on app option I cant zoom in the image
Hi people!
When I use the Camera Remote application and try to check  images using the import images selected in the application option, I cannot zoom in on the image. When I zoom in on the image it looks low quality. It doesn't refresh and I can't check if the image is in focus. The zoom in only works for me when I use the 1: 1 factor.  I use the android app version
Does anyone else have this problem?
Thanks!!
XT3 / 16mm / 16-55mm / 56mm / 90mm
